Inconsistent results within VOF multiphase simulation with species transport |
Sangwoo Kim
Rep Power: 12 ![]() |
Hello!
I am simulating bubble column. The column is filled with water, and CH4 gas is injected from the nozzle submerged in the water tank. Above the water tank is N2. Brief setup is as follows: 2D volume-of-fluid (VOF) multiphase flow model Species transport model for secondary phase, that is, Phase-1: Liquid Water Phase-2: Gas mixture (CH4, N2) Left figure is the contour of the volume fraction of Phase-2 (Gas mixture). Bubbling phenomenon is well described, as you can see. Right figure is the contour of the mass fraction of CH4, which is one component of Phase-2. Fluent Theory Guide says that the mass fraction is multiplied by the volume fraction in the species transport equation (2021R1 Theory Guide 18.8 Modeling Species Transport in Multiphase Flows). Then, CH4, which is a component of Phase-2, must not exist in the region occupied by Phase-1. But, as you can see in the right figure, the contours of the volume fraction of Phase-2 and the mass fraction of CH4 do not match; it seems that CH4 is remained in the liquid region. Am I missing some steps? Any comment will be very helpful. Thank you!
Best regards Last edited by swtbkim; November 22, 2023 at 02:16. |
Species Transport | Anne009z | FLUENT | 0 | January 27, 2018 14:40 |
Using VOF model and Lagrangian Multiphase in the same simulation | ganesh_krishnan | STAR-CCM+ | 2 | March 17, 2017 01:34 |
Multiphase flow with species transport | hassism | Fluent Multiphase | 0 | August 29, 2013 14:33 |
vof with species transport | ch05d007 | FLUENT | 1 | September 13, 2009 23:26 |
Can we use VOF and Species Transport together | MANOJKUMAR | FLUENT | 3 | November 21, 2005 04:13 |
