Physical Model
Old   November 14, 2023, 04:10
Default Physical Model
isaac_h is on a distinguished road
Hi!
I'm doing a conjugate heat transfer analysis och my fluid temperature will vary, so for different cases my Reynolds number will vary from around 1000 to 6000 (pipeflow). What model would you use? I have now used the k-omega SST, but since in some cases the flow will be more laminar, I am not sure if this is the right approach.
As I understand it, it is not a good idea to switch model in between cases, for example if i would use the laminar model for R<2300 and the k-omega for everything above. My pipe has a smooth bend , but my region of interest is after the entry length after this bend. I have also added roughness inside my pipe to get the right pressure drop for the k-omega model.
Any insight on how to think here?
isaac_h is offline   Reply With Quote
Old   November 14, 2023, 04:13
Also, I have looked into the transition sst model, but it is more suiteble for aerodynamics and not so much for pipeflow if i understand it correctly?
laminar flow, model equation, transitional, turbulance
How creating new thermo physical model weiste01 OpenFOAM Programming & Development 11 May 8, 2020 16:08
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 20:42
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 06:26
OpenFOAM 13 AMD quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 1 November 11, 2007 00:23
