November 1, 2023, 06:10 |
streamline stops behind the blade
MACXS
Hi everyone,
I've modelled a picohydro turbin. As you can see from the image attached, the streamlines are stopping behind the blade and not going thru outlet Is there a way to make them pass through?. by th way i set up the parameters by using steady state Any advice? Thanks in advance. |
ansys, fluent, stream failure, streamline |
Fluent UDF Mesh Motion Issue: Blade Pitch w/ Respect to Azimuth Angle | recmvp | Fluent UDF and Scheme Programming | 0 | July 30, 2023 16:50 |
How to split air blade in CFX Post without loosing accuracy | JonasII | CFX | 7 | May 18, 2021 17:54 |
Gaps between Turbine Blade Rows | cdelorenzo | CFX | 1 | November 26, 2019 02:22 |
[TurboGrid] Slotted rotor Blade using Turbogrid | drcsm | ANSYS Meshing & Geometry | 0 | March 15, 2016 01:26 |
Problem in conducting CFD of analysis of wind turbine blade | atulpat | CFX | 16 | August 17, 2013 05:09 |
