Rep Power: 2 ![]() |
Hi!
I have a table of surface temperatures that varies along a pipe, and I want to put these as initial values and do a transient flow analysis, and observe what happens with the fluid and how the pipe cools down. How do I set these temperatures as initial values? As you understand I don't want to have the temperatures as boundary conditions, anyone know how to to this? Thanks ![]() |
fluent, initial conditions |
Compressible flows with larger Courant numbers | Tobi | OpenFOAM Running, Solving & CFD | 5 | February 26, 2021 15:20 |
Foam::error::printStack after large bounding epsilon events | StoneCFD727 | OpenFOAM Running, Solving & CFD | 1 | January 1, 2018 17:04 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 18:17 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
