October 30, 2023, 14:49 |
Droplet particle properties
Andrea
I want to model the combustion process inside a hybrid rocket engine that uses nitrous oxide as oxidizer and paraffin as fuel. I'm trying to model the injection of nitrous oxide as fractions of gas phase and liquid (droplet) phase and to do so I have to add liquid nitrous oxide as a new material since only the gas phase is present in FLUENT database. The models I'm using are the following: - Energy (on) - Viscous (standard k-eps, standard wall fn) - Species transport (see attachmentScreenshot 2023-10-30 162516.jpg) - Discrete phase (interaction with continuous phase on) I'm using the following table to create the liquid nitrous oxide as a new materialScreenshot 2023-10-30 163037.png. the translation for each parameter is: - Reference state - density - specific heat - specific enthalpy - specific entropy - dinamic viscosity - latent heat of vaporization - superficial tension - boiling point The table is taken from a paper in which the authors use these data to create the matrerial in FLUENT but I'm unable to find all the parameters in the create material window as seen in the images below. Screenshot 2023-10-30 162248.jpg Screenshot 2023-10-30 162258.jpg Do you know how to set these parameters? Do I have to change some models settings? I would really appreciate some help as this is my first simulation using ANSYS. |
December 12, 2023, 11:49 |
RE: Nitrous Oxide multiphase flow - liquid and gaseous phase
Alabama
Hi Andrea!
Disclaimer I am also looking at a similar situation. I am still pretty new at Ansys, however I will do my best to give you helpful feedback. It's possible some of my feedback may not help. If there is any additional information you can provide about your particular case, I would appreciate it! ************************************************** ************* Questions 1. Why did you choose K-epsilon instead of K-omega? K omega is better for near-wall flow regions, where adverse pressure gradients are significant, which I would imagine is important for an atomizer, in your case. Though I did some quick reading and saw that K-epsilon had better reattachment through a nozzle. 2. Are you able to allow your liquid cp to stay constant for your particular case? If so, I successfully created a second (identical) nitrous-oxide Fluid in the materials tab, and then renamed it "liquid_nitrous_oxide" so that cp was constant. ************************************************** *********** Sources: K-Omega for Atomizers <https://link.springer.com/article/10.1007/s40831-021-00370-2> |
combustion, droplet, dropletsinjection |
Law 2 Evaporated Droplet Model: When particle reach Tvap, then particle temp drop | Wut | FLUENT | 0 | July 13, 2022 10:23 |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 13:30 |
Droplet particle collision | Hossein1 | Fluent Multiphase | 1 | August 17, 2015 08:29 |
Modelling for capture of dust particle by droplet | NK | CFX | 8 | May 20, 2015 06:35 |
droplet separation off a particle in turbulent stream | anonymous_89 | Main CFD Forum | 0 | August 22, 2013 13:40 |
