How to set thermal boundary conditions
Old   October 29, 2023, 05:47
Default How to set thermal boundary conditions
wuhaibin
HB833 is on a distinguished road
Hello everyone, I now have a pipe with fluid A inside and fluid B wrapped around the outside for heating. Fluid B is 443.15K steam that enters from the upper inlet. Now I need to set the boundary conditions for fluid B. My choice is: temperature,443.15K. Is this reasonable?
HB833 is offline   Reply With Quote
Old   October 30, 2023, 06:38
Laurens
LJA_Koers is on a distinguished road
It looks like you have fluid A enclosed by a solid but haven't dont so for fluid B, why?
Usually, the interface between a solid and fluid is modeled as a coupled BC. I would apply the 0 heat flux condition here as you are cooling the steam and the temperature condition is probably not adequate.
Have you thought about what condition you'd apply on the solid sections which enclose the inlet and outlet of fluid A? These are often set as a zero heat flux condition, but in reality there will be heat condition along the pipe that is out of the domain now. I usually set this as a heat flux determined by the temperature of this surface and the average temperature of the same surface offset a little along the length of the tube.
LJA_Koers is offline   Reply With Quote
fluent
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
