Residuals not converging
Old   October 26, 2023, 13:05
Default Residuals not converging
Thorben
thorbo is on a distinguished road
I have a problem with my residuals not converging. For my Master Thesis I need to simulate the Flow of a transformer housing. Im doing a steady simulation using realizable k-epsilon turbulence model with capable wall functions. As you can see, after some time the residuals, especially the continuity residual are not converging anymore. I also put some monitor points in the domain. The velocitys at the monitor points are oscillating around a value.
It seems like the problem is transient and not steady, am i right? I already tried refining the mesh, but no difference.
Does somebody know, what might be wrong with my simulation or do i have to do a transient simulation? The steady simulation already took 20 hours so a transient simulation would take a lot more time I guess.
I´m quite new to cfd so please dont hate if it is a stupid question.
thorbo is offline   Reply With Quote
Old   November 1, 2023, 09:36
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Results you mentioned never say that they are not converged. I do not know what made you think about this? your resdiuals just indicate that they are not going further down. There is mesh limiation that is not enabling the solution to converge more. Therefore, it is recommended to monitor other points for convergence that you already placed. If they follow a constant behaviour that they are observing (as indicated by your pics), then they are converged. So no need to see residuals further. Rest, if the phenomenon is itself time dependent then transient simulation is obvious. o/w no need.
Shamoon Jamshed is offline   Reply With Quote
Residuals converge initially, then stop converging andrew-c FLUENT 2 April 6, 2023 13:12
Residuals not converging properly kishore208 OpenFOAM Running, Solving & CFD 0 April 23, 2022 09:52
Residuals aren't converging Germanchoacr FLUENT 0 April 16, 2022 17:50
Pimplefoam - residuals not converging cyln OpenFOAM Running, Solving & CFD 16 November 7, 2017 13:46
strange residuals - converging -then diverging- then oscillating - then getting weird juste FLUENT 3 December 3, 2016 18:26
