Is it possible on Fluent to launch analyses based on geometry changes?
Old   October 24, 2023, 12:45
Default Is it possible on Fluent to launch analyses based on geometry changes?
hadil
hadmess is on a distinguished road
This is a theoritical question out of curiosity.
I want to run a simualtion on fluent for heat treatment where we change boundary conditions and parts geometry.
For the boundary conditions, I know it is possible to run a parametric study and add new design points to change the conditons for the simulations but what about geometry.
For example, if you define a value D as the diameter of the part, will the design modeler adjust the geometry, mesh and run the simulation for all the diameters you specify?
Thank you!
hadmess is offline   Reply With Quote
mesh and fluent, parametric analysis, parametric geometry
Geometry not visible in Fluent solution setup gehannes FLUENT 1 May 20, 2018 14:20
Generation of geometry in Fluent Shayankhan FLUENT 2 February 16, 2018 06:45
[Gmsh] Gmsh geometry into Fluent Kelda OpenFOAM Meshing & Mesh Conversion 0 September 13, 2016 08:50
[DesignModeler] Import geometry from Fluent6.2 to ANSYS FLUENT panos karvounis ANSYS Meshing & Geometry 0 July 14, 2016 06:25
Importing geometry in Fluent Tanjina FLUENT 10 June 5, 2013 15:13
