Post processing contours in ansys fluent (exploded view contour planes) |
October 17, 2023, 07:06 |
Panagiotis Artemiou
Rep Power: 3 |
I am trying to post process some contours. I have channells inside of which is the fluid flow, and i want to present the velocity field in 3 different planes as shown in the image i am attaching. However in the scale of the model, these planes are too close to each other. Is there a way to move the planes a bit further away from each other for a better view? But maintain the velocity field of the original planes. Essentially, I want to move them apart just for presentation purposes. Thank you very much! |
contours, planes, post procesing |
Ansys Fluent Post Processing | Yew | FLUENT | 0 | May 3, 2022 00:16 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
section view in Ansys Fluent Design Modeler | Mehroze | FLUENT | 1 | November 7, 2013 04:52 |
fluent for post processing | James | FLUENT | 0 | April 21, 2006 04:43 |
