How does Inlet and Outlet corelate with sst k-omega equations? |
October 15, 2023, 14:22 |
Anton Bainov
Rep Power: 3 |
Hello, I'm newbie to CFD and Fluent in particular, and I'm trying to understand how does velocity inlet and outflow boundary is defined in sst k-omega equations? I understand that sst is using F1 and F2 to define ratio between k-omega and k-epsilon for walls, but what about domain inlet and outlet parameters?
P.S. I'm trying to recreate naca validation case |
October 15, 2023, 18:00 |
Lucky
Rep Power: 66 |
Outlets are outlets.
At inlets, you provide all the transport variables needed for the model, including turbulence model. That means you provide, velocities, temperature, pressure, k, epsilon. |
October 15, 2023, 19:51 |
#3 | |
Anton Bainov
Rep Power: 3 |
I understand that we provide variables, but which part they take in these equations? https://www.afs.enea.it/project/nept.../th/node66.htm Especially, how do we calculate velocities etc. near inlet, or do we always set the velocities in inlet to certain values that we assigned nevermind the new values after iteration? |
October 16, 2023, 21:01 |
Lucky
Rep Power: 66 |
You have a boundary value problem. That means at interior cells you solve transport equations. At boundaries, you have boundary conditions.
The only difference between inlet types is whether you specify velocity, pressure, or mass flow. A velocity inlet means at the inlet, you directly specify the velocity at every boundary cell. That's why we call it a velocity inlet. At any inlet, you specify all other variables. So if you have a k-epsilon turbulence model, which has a transport equation for k and a transport equation for epsilon, then you specify k and epsilon at the inlet as a boundary condition. If you have a transport equation for apples, then you specify the value of apples at the boundary. If you have a transport equation for pineapple smoothies, then you specify the value of pineapple smoothies at the boundary. If you have a k-omega model, you specify k and omega. If you have a k-omega SST model, then you specify k and omega. Refer to the Reynolds transport theorem for what is a transport equation. Transport equations are solved in the interior. Boundary conditions are constraints imposed on the solution at boundaries. |
October 16, 2023, 21:18 |
#5 | |
Anton Bainov
Rep Power: 3 |
fluent, naca, sst k-omega, sst komega |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
using outlet velocity profile as inlet for next set of iterations | tricha122 | FLUENT | 0 | November 22, 2020 10:40 |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? | p07ip705 | Main CFD Forum | 3 | August 3, 2012 06:53 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
