Suitable method for Y+<1
Old   October 13, 2023, 12:19
Default Suitable method for Y+<1
mohammad
un-cfd is on a distinguished road
hello everybody
I will simulate several cases of heat transfer in a channel with heated blocks, some in laminar and others in turbulence status. Because in turbulence status Re is low, the first mesh thickness is very small of y+=1 status. I won't be able to change the mesh, then wich turbulent method can simulate this case??
un-cfd is offline   Reply With Quote
heated block, turbulance, yplus
Solution method michimichi88 Fluent Multiphase 0 May 13, 2015 12:35
fluid flow but temperature raises from nowhere? mxcfd STAR-CCM+ 5 September 16, 2014 06:46
Turbulence inflow generation - recycling method panda60 OpenFOAM Running, Solving & CFD 15 April 25, 2013 02:34
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 11:55
Is SIMPLEC method suitable for turbomachinery? lhb Main CFD Forum 14 February 15, 2001 20:59
