Fan simulation
Old   October 13, 2023, 07:04
Question Fan simulation
Geetanjali Alle
Geetanjali is on a distinguished road
Hi, i am simulating an enclosure with 2 fans, a few heat sources on a heat sink and a few components placed on the PCB. I did all the necessary boolean operations. I kept getting failed mesh due to overlapping connections. So to solve it, I added components to a new part and increased the tolerance of contacts.
In fluent,
I used the transient solver with k-epsilon model with std function,
Assigned source term to bodies,
Mesh motion to the rotating domain,
Pressure inlet with 60 deg C temperature and a pressure outlet,
In mesh interfaces, I added coupled wall,
SIMPLE model with 2nd order discretization
The solution keeps diverging. I am unsure if it is because of the mesh overlapping connections or fluent settings. Any help would be great. Thanks.
Geetanjali is offline   Reply With Quote
divergence amg solver, fan, fluent, mesh, overlapping
How to represent a fan on a simulation? igor.leo93 OpenFOAM Running, Solving & CFD 4 June 21, 2022 20:55
Axial fan simulation setup D-man FloEFD, FloWorks & FloTHERM 3 September 10, 2021 10:49
Residual Divergence Issue In Convective Fan Cooling Simulation JulianH STAR-CCM+ 2 February 28, 2020 12:52
Fan simulation with inlet and outlet duct for finding fan curve chaudhry_hashim FLUENT 0 August 6, 2014 11:49
Fan simulation with inlet and outlet duct chaudhry_hashim STAR-CCM+ 0 June 27, 2014 09:59
