October 12, 2023, 15:56 |
Setup issue in fluent
Rana abdo
Rep Power: 3 |
I have got some rough surfaces data that i have attached on a ship these surfaces differ from each other one has low density of roughness and the other is very rough. After attaching these surfaces on the ship the ship has become with a rough geometry but the difference of these surfaces are in microns. The problem is when i use fluent to calculate the drag on the ship having these two rough surfaces the values are the same although the roughness have changed.
What could be the problem Note : when i use different y+ value the drag changes so how can i set the y+ value for the ship surface. Also there is new cell domain that appears that os called fluid other than the orignal one and a wall shadow so what is the reason behind this. I couldnt split the domain in space claim the rough ship surface causes error in the geometry |
ansys, fluent 19.1, roughness, space claim, y+ values fluent |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 10, 2022 00:58 |
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle | FelixJJ | FLUENT | 2 | October 20, 2021 03:39 |
Fluent Giving Different Results For Same Analysis Setup | Murwin12 | FLUENT | 0 | March 6, 2019 12:00 |
fluent issue in windows hpc pack 2012 r2 | mosesHPC | FLUENT | 17 | January 12, 2019 16:01 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
