Rotation is not simulated MRF
Old   October 12, 2023, 05:14
Default Rotation is not simulated MRF
CAP_NJ is on a distinguished road
Hi together, I have an issue with the MRF model for two domains. I have a rotor ("passage" fluid domain) and a stator ("passge_1" fluid domain) and set up the corresponding mixing plane and domain settings (most of it done by the torbo_workflow), but it seems the rotation is not simulated. This can bee seen on the velocity plot after simulation. The direction in both reference frames are the same. Do have an idea, what I am doing wrong? Thanks in advance and best regards!
CAP_NJ is offline   Reply With Quote
multiple reference frames, reference frame, turbo machinery, turboworkflow
MRF not working with chtMultiRegionFoam nikoscham OpenFOAM Running, Solving & CFD 2 January 25, 2023 07:00
Modeling Wheel Rotation using MRF Lukas7117 FLUENT 0 December 1, 2020 11:19
Modeling Wheel Rotation using MRF Lukas7117 Main CFD Forum 0 December 1, 2020 11:03
Rotation Velocity in MRF for a Rotor Hybrid FLUENT 5 September 17, 2015 10:20
MRF rotation in unstady simulation Clementhuon Siemens 0 May 25, 2012 03:45
