October 5, 2023, 08:13 |
Residuals do not converge?
Julia
Rep Power: 3 |
I tried solving my model with 1000 iterations and got the residuals shown in the attached picture. How do I get the simulation to converge?
A 2D-Sketch of the model is attached. The BC's are: - mass flows inlet & outlet: 2e-5 kg/s - velocity inlet: 14 m/s - all other enclosure areas got a BC with pressure-outlet: 0 Pa The settings for the solution: Solver Type: Pressure-Based Solver Time: Steady Model: k-omega (2 eqn), SST Mesh Quality: - Skewness (Surface): Max = 0.605; Avg.= 0.016 - Orthogonal Quality (Cells): Max = 0.206; Avg. = 0.917 - Aspect Ratio: Max = 94.89; Avg. = 10.61 Cells with an aspect ratio above 5 are almost only in the inflation layers of the box. The enclosure is in all directions at least 5 times the length of the box in that direction. Also, I put a Body of Influence around the box. I am interested in the general behavior of the flow behind the box (so in front of the mass flow inlet & outlet). I watched many CFD-Videos but am still a newbie to it.. So I think, the Quality of my mesh is good? But then I don't get why my residuals won't converge. Can anyone help me? |
external flow, residuals fluent |
Residuals converge initially, then stop converging | andrew-c | FLUENT | 2 | April 6, 2023 12:12 |
Relative residuals for solid solver doesnot converge for fsiFoam | ARTisticCFD | OpenFOAM Running, Solving & CFD | 1 | June 28, 2022 23:22 |
PimpleFoam runs full length even after residuals converge! | walakaka | OpenFOAM Running, Solving & CFD | 3 | February 28, 2018 13:08 |
VOF transient: Should residuals converge at each time step? | jpina | Fluent Multiphase | 1 | April 9, 2016 02:26 |
Residuals converge then explode | plm | OpenFOAM Running, Solving & CFD | 2 | December 31, 2011 07:35 |
