Rep Power: 2 ![]() |
I create a scalar transport equation using UDS in Fluent and I need to implement Neumann boundary, which can be expressed as Fig1. ![]() Moreover, the equation I solved is needed to calculate for many times since the deltaT is changed by me, that is, after flow equation solved once, my equation gets results(velocity pressure) from flow field and the deltaT is changed into 1/10 of the flow_deltaT. However, the DEFINE_ADJUST is execute before the calculation of flow fields. Once my equation begins to solve, the DEFINE_ADJUST won’t work, that is, since my equation is needed to be solved 10 times in one flow time-step, in the first calculation of my equation, it works; but in the second calculation, it won’t work since the DEFINE_ADJUST is only execute once. Simply, if DEFINE_ADJUST can be used, how to maintain it during many calculation within one flow time-step. ![]() |
does anyone have any ideas? |
fluent - udf, udsi |
Neumann boundary condition for heat flux using UDF | Yadu krishnan | Fluent UDF and Scheme Programming | 6 | September 14, 2021 07:53 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Neumann Pressure Boundary Condition with UDF | Balder | Fluent UDF and Scheme Programming | 8 | July 6, 2012 11:21 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
