Determining Turbulent or Laminar Flow in Regions with Varying Reynolds Numbers |
September 24, 2023, 05:10 |
Rep Power: 6 |
I encountered an issue while setting up the fluid model in Fluent. Suppose a pipeline has an inlet velocity satisfying a Reynolds number less than 2300. However, in certain corners within this region, the velocity corresponds to Reynolds numbers exceeding 2300. Should the model for this region rely solely on the inlet velocity to classify it as laminar flow, or should it be classified as turbulent flow because there are locations within the region where the velocity exceeds a Reynolds number of 2300?
September 24, 2023, 12:24 |
Lucky
Rep Power: 66 |
The flow is turbulent or laminar by its own nature. No magic formula changes it.
Some parts of the universe maybe laminar and other parts may be turbulent. If you suspect certain regions to be turbulent then use a turbulence model there and use a laminar model in regions that are laminar. One model might not work for both cases, they rarely do. |
September 24, 2023, 23:15 |
Rep Power: 6 |
Thanks for the reply. I still wonder how to suspect certain regions to be turbulent. Is there a standard to determine whether a certain area is turbulent or is it based on experience? Alternatively, could I initially employ a laminar model to compute and examine the velocity vector map to see if there are any vortex regions as a means of identifying turbulence?
laminar flow, reynolds number, turbulent flow |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Reynold's number calculation for Laminar and Turbulent flow | Raza Javed | OpenFOAM Running, Solving & CFD | 0 | May 22, 2019 07:37 |
Turbulent flow entering laminar domain | arjdk | FLUENT | 0 | November 21, 2017 04:38 |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 07:45 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
