Error in Conjugate HT Problem
Old   September 18, 2023, 02:14
Post Error in Conjugate HT Problem
Naimish Pandya
Naimish is on a distinguished road
I'm doing a simulation on air is flowing inside a hollow duct with minimal thickness. The upper and bottom wall of the duct has some turbulators mounted with the wall it self and constant heat flux is applied on 4 wall of duct.
I'm getting this error
Reversed flow on 12 faces (0.0% area) of pressure-outlet 69.
64 5.5787e-03 1.1695e-05 2.5169e-06 2.8083e-06 3.7085e-05 2.3229e-03 5.4864e-05 18:36:51 5436
My turbulent model is Komega SST and how I can solve this?
Boundry condition at Inlet and outlet is mass flow and pressure.
Naimish is offline   Reply With Quote
Old   September 18, 2023, 21:33
CFDKareem's Avatar
Kareem
CFDKareem is on a distinguished road
Recirculating flow at the outlet isn't always a problem as long as its far away from your region of interest. To eliminate the error you can pull the outlet further away from your ROI. You can also increase the mesh size as the flow moves away from your ROI, within limit, to make sure the flow is moving in the streamwise direction.
Please like the answer if it helped!
Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured
CFDKareem is offline   Reply With Quote
Y plus display in CFD-Post in a conjugate problem harryosu ANSYS 2 June 26, 2019 18:31
Issues with creating "regions" for conjugate heat transfer problem!! vabishek OpenFOAM Pre-Processing 6 April 23, 2015 17:23
Problem with conjugate heat transfer in Fluent JianT88 FLUENT 0 March 16, 2015 09:17
Shell conduction and Conjugate problem RBM FLUENT 1 October 24, 2005 13:20
conjugate heat transfer problem Andreas CFX 1 February 5, 2002 19:22
