September 14, 2023, 15:31 |
Closed loop system convergence problem
raihan
Rep Power: 11 |
Hi Everyone,
I have a system with no inlet or outlet. The simulation domain is a room. Air is pushed into the room by a fan of an AC unit. The air leaves the room through a vent. A duct loops the air back to the fan inlet. I am not concerned about the temperature field for now. I need some suggestions about how to initialize the system because running the simulation with the default hybrid initialization method fails to converge. Thank you. |
September 14, 2023, 16:38 |
Solved!
raihan
Rep Power: 11 |
You need some idea about the flow in the domain. Then initialize the system using standard initialization with some approximate velocity or pressure. I just initialized the system with a velocity parallel to the fan inlet's normal direction and it worked.
All praise to Allah! |
closed loop cfd, convergence, initialization method |
Convergence problem for air-water system with population balance model | Max30 | Fluent Multiphase | 0 | January 8, 2023 08:47 |
Closed loop heat exchanger in fluent | soankerabhinay | Main CFD Forum | 0 | August 23, 2021 01:30 |
Simulating Cooling Jacket and Convergence Problem | luzikato | FLUENT | 0 | January 1, 2021 08:56 |
Problems with convergence with an easy system | franzdrs | Main CFD Forum | 0 | June 15, 2009 19:17 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 14:43 |
