INERT: net mass flowrate ≠ zero
Old   September 12, 2023, 07:47
Default INERT: net mass flowrate ≠ zero
Josephine Narciso
rreo is on a distinguished road
Hello! I am doing a simulation for a microchannel reactor with catalyst washcoat, located at the top of the channel. The feed (consisting of CO2, H2, and inert N2) will flow through the channel inlet, then the porous catalyst washcoat, and to the channel outlet. I used UDF to define the source term needed for the hydrogenation reaction.
Now, my problem is the mass flowrate of my inert N2. The net flowrate (based on channel inlet and outlet) should be equal to zero, but I have a problem in achieving this since the mass flowrate of N2 at the outlet is higher or lower than the inlet.
I wanted to address this by assigning a fixed value of N2 at the catalyst washcoat cell zone conditions. However, this is not possible since N2 is placed last in my mixture-template. I also cannot put the other species at the last since I need to assign source term for each of the species, both reactants and products.
I also saw the inert model in the fluent theory guide, but I can't seem to find it on the version 19.2 of Ansys.
I would like to ask if there are any possible ways on how I can indicate the presence of inert in my feed.
rreo is offline   Reply With Quote
fixed value, mass flow rate
mass fraction of species Lilly FLUENT 5 March 13, 2022 18:52
Calculate Mass Flowrate and Mass Flow Averaged Total Pressure at inlet and outlet coolcrasher OpenFOAM Post-Processing 7 November 4, 2021 05:57
negative net mass flow rate luccy Fluent Multiphase 8 September 2, 2015 05:33
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
