rshettCFD
Rep Power: 2 ![]() |
Greetings everyone,
I am working on dilute sand slurry flow in pipes (0.001 v/v) with water as the carrier phase. The issue I am having is that there is increased sand settling observed ONLY at the boundary layer (even above critical settling velocity) The turbulence model I am using is the k-epsilon model, RNG, Dispersed flow. My Y+ is around 15. The sand size is 0.0003 m. The first layer thickness in my mesh is 0.0006 m. My underlying question is regarding the C_mu value to tackle to spike in turbulent kinetic energy at the Boundary layers. Any help will be deeply appreciated. Thanks, and kind regards. |
dispersed flow, k-epsilon model, rng |
viscosity of fluid and impact on flow on a fixed supply line | Henry04 | Main CFD Forum | 1 | December 27, 2021 21:31 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
example of dilute gas-particle flow - Eulerian model | talib | FLUENT | 0 | March 13, 2012 05:18 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
