Solid Oxide Electrolysis Cell (SOEC) Simulation - Profiles for Current Densty
Old   September 7, 2023, 09:21
Lightbulb Solid Oxide Electrolysis Cell (SOEC) Simulation - Profiles for Current Densty
Raśl Sotillo
raulsotillo is on a distinguished road
Hello!
I am simulating a basic SOEC electrolyser on ANSYS Fluent and I am wondering about those high current density areas in the results of my simulation (image attached).
In my model, the channels (10x20 cm) go through an interconnector, and the rest of the layers are 20x20 cm which is the size of the squared area of the electrolzser
That indicates that a high current density is passing that area when in reality the maximum values should be at point where the red area starts to generate.
Could you help me with this matter?
Thank you!
Raśl
File Type: png Captura de pantalla 2023-09-07 141624.png (95.9 KB, 3 views)
raulsotillo is offline   Reply With Quote
current density, soec, solid oxide
Solid object falling in water tank simulation cassini83 CFX 3 August 9, 2021 18:05
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Rigid Body State Variables in Solid Immersed Simulation Hamidreza CFX 1 October 19, 2009 07:14
Warning 097- AB Siemens 6 November 15, 2004 05:41
