Specified the mass flow or velocity with internal condition |
September 1, 2023, 01:03 |
Jie-Ying Zhan
Rep Power: 3 |
hey guys,I realy need some advice,please help me.
As the title, I'm simulating a data center case, and I want to specify the flow rate behind each rack(with face). Obviously, I can't use inlet or outlet boundary conditions, so I want to know if there is a way to directly specify the flow velocity or flow rate on that face(maybe with internal condition or something else?). |
September 1, 2023, 11:18 |
Kareem
Rep Power: 5 |
I think you are looking for an internal fan condition. If you have two faces in contant you can specify a pressure jump across the face. This simulates a fan taking air in from one side and accelerating it back into the domain.
check out the fluent manual for more details on using the internal fan boundary condition
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
boudary condition, data center, mass flow |
Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 06:58 |
Velocity, Pressure or Mass flow inlet condition | brwmkprules | Main CFD Forum | 3 | January 6, 2017 12:06 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 18:24 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 03:19 |
