How to turn dynamic load balancing off for dynamic mesh?
Old   August 29, 2023, 05:18
Default How to turn dynamic load balancing off for dynamic mesh?
ss
flyingsquirrel is on a distinguished road
I found that if dynamic mesh is there in Ansys fluent then the Dynamic loading balancing is forced to be turned on (see attached). But since I am using the udf that relies on a constant partition for parallel computation, it'd be right to prevent Fluent from re-partitioning cells to different computing cores. Is there any way to turn the greyed-out tick off?
flyingsquirrel is offline   Reply With Quote
dynamic loading balancing, dynamic mesh, prallel
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
Dynamic Mesh kennyboy FLUENT 1 February 23, 2019 02:52
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh Emanuele88 FLUENT 0 February 9, 2016 12:39
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
