cm vs alpha graph of an airplane on ansys fluent |
August 28, 2023, 05:50 |
Rep Power: 3 |
Hey everyone.
I have to find the cm (pitching moment coefficent) vs alpha graph of an airplane using ansys fluent. What is the aproach ı have to take to solve this problem. Thanks already. |
August 28, 2023, 14:27 |
Rep Power: 19 |
1. Build a grid of said aircraft
2. Set the angle of attacjk along with boundary conditions, freestream parameters and whatever else your flow solver needs. 3. Run the flow solver to generate a solution and compute the moment coefficient using the flow solution. 4. Plot the coefficient against that value of AOA. 5. Repeat steps 2-4 until you have generated a desired curve. Now if you are looking for fluent specific knowledge, you might want to try the fluent specific forum. |
August 29, 2023, 05:23 |
Rep Power: 3 |
Hey
I see. I thought there woulld be a faster way than making a new mesh every time but that can work too. Thanks for your suggestion. |
August 29, 2023, 10:25 |
Stuart
Rep Power: 26 |
You do not have to make a new mesh for each AoA. Just make a suitable mesh and change the freestream velocity components for each simulation.
In Fluent there is the far-field boundary condition for this type of simulation. It's efficient to make a spherical (full-aircraft) or hemispherical (half-aircraft due to symmetry) computational domain. |
ansys fluent, dynamic mesh |
how to run fluent from matlab without using aas toolbox? | artemis96 | ANSYS | 7 | May 23, 2022 13:16 |
[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? | Ryan T | ANSYS Meshing & Geometry | 3 | November 3, 2021 16:44 |
Ansys Fluent meshing vs Ansys Meshing | amd2424 | FLUENT | 1 | May 10, 2021 04:15 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 04:34 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 18:07 |
