Modelling soec using module 3 fuel cell and electrolysis
Old   August 27, 2023, 17:49
Default Modelling soec using module 3 fuel cell and electrolysis
SH
lavendar12 is on a distinguished road
I am modelling soec using module 3 fuel cell and electrolysis, using electrolysis option. from the manual, the steam is provided at the anode (fuel electrode), and air is at the cathode, may I know how should I set up the voltage, let say the cell voltage is at constant voltage is 1.3V, should I set up is 0V at the anode and 1.3V at the cathode as per manual? or the other way around?
I found this in the manual, and a bit confused on setting up the voltage for the electrolysis mode for soec.
Note that, conventionally, the negative voltage is supplied to the cathode side in power consuming devices such as electrolyzers. ANSYS Fluent adopts the inverse notation where the negative voltage is supplied to the anode side whilst cathode remains positively charged. The main reason for this discrepancy is that the same infrastructure is used for both the electrolysis and fuel cells models. Usage of the terms "anode" and "cathode" in this manual and in the user interface should be interpreted according to conventions for power-supplying devices.
The model seems to work when I put -1.3V at the anode sides, may I know if this is right?
Thank you!
lavendar12 is offline   Reply With Quote
cell voltage value unphysical in addon module 3 fuel cell lavendar12 FLUENT 0 July 18, 2023 09:14
Loading the Fuel Cell and Electrolysis Module Grainrain FLUENT 3 May 27, 2021 23:23
Fuel Cell module: Extreme electrochemical reactions and electric currents P.Charoen-amornkitt FLUENT 6 March 23, 2019 12:01
SOFC with Fluent's Fuel Cell Model D Bhardwaj ANSYS 6 March 30, 2018 12:59
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 March 1, 2016 00:56
