Natural convection flow boundry conditions and timestep |
August 23, 2023, 13:25 |
Natural convection flow crazy fast velocity
Dale
Rep Power: 17 |
Hi, I am running a natural convection, buoyancy driven flow problem in Fluent. I have attached a picture for reference. My goal is to find out what the max velocity will be. To minimize mesh size I am just doing 2D for now because the geometry is large. If you look at the picture the right vertical wall is heated with constant temp. The inlet and outlets are exposed to the atmosphere. Initially all the fluid (air) will be at rest and as the right vertical wall heats the air it will rise and create a flow upward. I have defined density, viscosity, thermal conductivity as curve fit polynomials as a function of temperature. Inlet and outlet are pressure inlet and pressure outlets set to 0 gauge pressure and operating pressure was left default 101325 Pa. I am also doing timestep of 0.1s up to 5 seconds (50 timesteps). I am getting crazy fast velocities like over 150m/s.
Thanks Last edited by Dale MC; September 14, 2023 at 22:09. Reason: new picture and more info |
bouyancy driven flow, natural convection bcs, natural convection flow |
What are the best settings for a channel flow simulation? | Ashkan Kashani | CFX | 3 | October 13, 2022 22:36 |
Diverging solutions for natural convection flow at differentially heated vertical wal | SonnyD | OpenFOAM Running, Solving & CFD | 0 | May 26, 2021 13:20 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 05:28 |
Natural Convection channel flow using openfoam | Rasesh | OpenFOAM Running, Solving & CFD | 1 | July 4, 2013 11:13 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
