Poly-hexcore mesh and symmetry
Old   August 23, 2023, 03:56
Default Poly-hexcore mesh and symmetry
Nawaf
NAWAF is on a distinguished road
Hi there,
I faced a problem in Ansys Fluent where I was simulating an external aerodynamics case but I found the solution and wanted to share with you guys.
Problem:
The case was half of a wing and at the root of the wing there is a symmetry boundary condition, the mesh was generated using Fluent meshing with volume mesh of poly-hexcore. The problem was that the residuals were converged and solution monitoring outputs were constant, but the pressures and velocity contours show a constant value through the whole flow domain, and this value was not logical at all.
Solution
After several trails it was found that this error was because the poly-hexcore mesh. Somehow poly-hexcore mesh seems to be not working with the symmetry boundary condition. When I changed the volume mesh to polyhedra I got a logical results and the solution was converged and everything was ok.
If anyone knows about this error or have a certain document please share it with us
NAWAF is offline   Reply With Quote
ansys, error, fluent, fluentmeshing, symmetry
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[snappyHexMesh] non uniform mesh near the stl object vava10 OpenFOAM Meshing & Mesh Conversion 0 January 31, 2021 15:41
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
