Performance of Models with large amount of solids
Old   August 17, 2023, 14:45
Default Performance of Models with large amount of solids
D2Net15 is on a distinguished road
I have a model with a large amount of solids (>100), which are in a fluid domain.
In some solids heat is generated and transferred to the surrounding fluid.
The mesh is imported from an external .cbd file, where every solid is a fluid at first.
In the journal file I've written, the fluids (which are solids in reality) will be changed to solids.
This takes really long due to the generation of shadow surfaces.
My question is:
Is there a convenient way to speed up this surface generation (maybe by even omitting it)?
Thanks a lot in advance 🙂
D2Net15 is offline   Reply With Quote
fluent, performance, shadow surfaces
[ICEM] select large amount of elements by element number lazybone ANSYS Meshing & Geometry 0 July 19, 2018 12:06
AMI memory leak? MichiB OpenFOAM Programming & Development 14 August 1, 2015 19:18
CFD modeling of large amount of spheres skonda2 Main CFD Forum 1 October 28, 2014 15:10
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 15:36
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 16:01
