August 13, 2023, 06:21 |
Terminating a list does not work in scheme
Rep Power: 5 |
I have the following scheme script:
(do ((x 1 (- x 0.2))) ((< x -2)) (ti-menu-load-string (format #f "display/objects/edit velocity-contour surfaces-list (z=~a) ()" x)) (format #f "/display/objects/display velocity-contour") (set! x (* x 1000)) (ti-menu-load-string (format #f "/display/save-picture ./pictures/velocity-contour-z=~a" x)) (set! x (/ x 1000)) ) which breaks because after (z=~a) the () doesn't do anything. It continues thinking I'm entering a surface name, so the rest of the commands are entered as the string. I have spammed () everywhere, tried q, nothing works. Wtf is going on? |
August 13, 2023, 06:27 |
Rep Power: 5 |
August 13, 2023, 11:24 |
Lucky
Rep Power: 66 |
The error is saying z=0 isn't a valid surface, not that () doesn't work in scheme
August 13, 2023, 11:49 |
#4 | |
Rep Power: 5 |
August 13, 2023, 13:40 |
Lucky
Rep Power: 66 |
So you have proved that the error was not () not working in scheme, great!
You are using a formatted string, and if you look, you actually printed what you interpreted as two scheme commands as one line |
August 13, 2023, 13:57 |
Rep Power: 5 |
Could you please explain this a little? In my script the commands are in separate brackets and with a new line between them, but like you said it's as if the tui doesn't recognise that, which I don't fully understand
FLUENT Scheme to get Contour names as a list | anan12345 | Fluent UDF and Scheme Programming | 1 | February 2, 2022 20:32 |
can you tell me best gradient, pressure & momentum order selection in fluent | sanjiiv | FLUENT | 6 | February 14, 2020 07:07 |
LimitedCubic scheme does not work | haoyuan | OpenFOAM | 0 | August 11, 2017 11:37 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
RP_Get_Real and the scheme list! | Kamal | FLUENT | 1 | December 2, 1999 22:53 |
