August 6, 2023, 00:00 |
How to wrap only some objects together?
Rep Power: 5 |
So I'm wrapping an FSAE car where the rollhoop is not attached to the body. If do a collective shrinkwrap on all the cad bodies, it adds a nasty big fillet as expected over the gap, which I don't want. I can add a fillet in cad and solve this issue but the gap here I feel would change the flow behaviour (and save me prisms). Is there a way to wrap the car body + wings + wheels etc, and wrap the roll hoop separately?
Here is what that gap looks like, rollhoop in green: https://puu.sh/JN43w/3049effaf3.png It only adds the fillet along the side of the car, not when it goes over the head of the driver, which is ok. I used to do a different method that didn't involve wrapping, and this gap doesn't cause any solution issues, so it'd be nice to get it working in the wrapping environment. Cheers |
August 6, 2023, 00:47 |
Rep Power: 5 |
I thought I'd found a way. Wrap the rollhoop object, then wrap everything else including the domain, then merge both mesh objects. Except when I compute volumetric regions, it gives me two. If I draw one, it's only the rollhoop. This is very strange since I merged the two objects previously into one surface mesh. Furthermore, since there are 'no shared face zones', I can't merge these volumetric regions. Any ideas?
Multiple Floating Objects with 6DoF in OF 2.3.0 | tyoung | OpenFOAM Running, Solving & CFD | 23 | June 11, 2024 02:13 |
Run function objects on final time | b.simpson | OpenFOAM Post-Processing | 3 | September 19, 2022 21:09 |
Multiple floating objects using InterDyMFoam and sixDoFRigidBodyMotion solver | FloatingSolar | OpenFOAM Running, Solving & CFD | 4 | December 29, 2020 12:09 |
[BladeModeler] Bladegen Radial Impeller Wrap Angle - Help Required | surajkashyap | ANSYS Meshing & Geometry | 1 | April 5, 2019 14:24 |
Update FOAM objects after new solver run | peterTr | OpenFOAM Programming & Development | 1 | May 11, 2017 17:26 |
