Mesh adaption approach for mixing flows
Old   August 3, 2023, 10:11
Default Mesh adaption approach for mixing flows
Laurens
LJA_Koers is on a distinguished road
Hi all,
For a burner design project, I'm initially trying to run a steady state, mixing problem of low caloric natural gas, 80% methane 20% N2, and air. The burner has 9 spuds and is axisymmetric. Because of the symmetry, I only model 1/9th of the domain. I want to use Fluent v21 R1's mesh adaption features to refine the mesh in the mixing region.
I'm however not sure what a proper mesh refinement criterion would be. Gradient or curvature based? And for what variable? Velocity, molar fraction or temperature?
I initially want it to refine for a steady case, and use transient mesh adaption later for a URANS and LES case. Any recommendation is appreciated! Figure with contour and mesh attached.
LJA_Koers is offline   Reply With Quote
adaption, cell, criterion, mesh, register
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
Mesh effects in high curvature flows JamesPMCFC OpenFOAM Running, Solving & CFD 1 November 3, 2022 18:04
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
