How does cfd package like fluent calculate parasite drag and induced drag? |
July 28, 2023, 10:08 |
bella lau
Hello everyone,
I am a newcomer to CFD and have encountered some questions regarding the calculation of induced drag and parasitic drag while using Fluent for simulations. I am wondering if Fluent allows direct output of induced drag and parasitic drag, but it seems that this feature is not available. I have learned that Fluent can export the lift coefficient CL and the drag coefficient CD. I am curious if we can calculate the induced drag coefficient CDi using the equation : CDi = CLČ / (π * e * AR)(Where CL is the lift coefficient, e is the span efficiency factor and AR is the wing aspect ratio), and then use the equation : CD = CD0 + CDi to obtain the parasitic drag coefficient CD0? I'm really looking forward to hearing from experienced members! Thank you all! |
July 28, 2023, 20:48 |
Lucky
Rep Power: 66 |
No need for complicated empirical formula.
Fluent does output induced and parasitic drag. Induced drag is nothing but the projection of the lift force. |
August 2, 2023, 08:54 |
bella lau
How can I achieve that?
fluent,parasitic drag, induced drag |
Induced downwash velocity for drag computation in Vortex Lattice Method (VLM) | Sehwan | Main CFD Forum | 3 | September 13, 2018 15:33 |
Induced drag, pressure drag, viscous drag. | aleix.de.toro | FLUENT | 2 | August 24, 2015 19:00 |
Determination of the induced Drag for a rectangular wing | matmax-168 | CFX | 3 | April 12, 2015 08:46 |
Calculating Induced drag of a wing from Trefftz plane analysis in FLUENT | pratikkr | FLUENT | 0 | May 16, 2013 15:14 |
Isolating wing induced drag component | siw | CFX | 2 | June 22, 2010 11:21 |
