alec
Rep Power: 0 ![]() |
Hi i have a problem with fluent : in design modeler when i want to import a profile from a file it says " error loading coordinates ". I use the 2020R2 version and the file is openend normally by anyone exept me and i connt figure out why ; I ve tried formatting computer more than 5 times but nothing. I attach the file i need to open here so that you can see that is easly openable and the file is not the problem.I currently use windows 11 but i ve tried with 10 as well and the problem is the same
coordinates from .txt, help me |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
