There is big difference in reattachment length for computational and experimental stu |
July 9, 2023, 05:26 |
ahmet
Rep Power: 3 |
Hello everyone!
I am studying on an unsteady Backward Facing Step (BFS) flow. My reference experimental study is the Li et al. (2020) "Effect of periodic perturbations on the turbulence statistics in a backward-facing step flow". In my results, there is a big difference in reattachment length compared the reference study. Reattachmen length is 4.2h in experimental study but in my study reattachment length is the 5.6. Is big difference between experimental and computational study normal? |
July 9, 2023, 20:20 |
Lucky
Rep Power: 66 |
In short yes, there can be massive differences in reattachment lengths depending on which models you use. k-epsilon is notorious for being borderline completely wrong.
However, you should keep in mind that reattachment length determined experimentally may be different than how it is determined in CFD. Experimenters and CFD'ers often have different definitions that can also lead to a 1h difference. Keep in mind reattachment should not be viewed as a phenomenon occurring at a well defined point in space, but a fuzzy area. |
July 11, 2023, 11:54 |
ahmet
Rep Power: 3 |
Thanks for help
cfd, fluent |
Validation of the reattachment length for pitzDaily tutorial case | Zymorui | OpenFOAM Running, Solving & CFD | 0 | July 25, 2018 09:45 |
3D Backward Facing Step (Reattachment Length) | nskelly | OpenFOAM Running, Solving & CFD | 3 | April 24, 2018 04:31 |
Reattachment Length using fluent | hasanifte | FLUENT | 1 | March 30, 2015 21:24 |
Difference between Experimental data and CFD-sim. | Bo Jensen | Siemens | 3 | January 23, 2001 09:00 |
