Ansys CFD Post Processing for Lift and Drag Coefficients
Old   July 7, 2023, 17:14
Default Ansys CFD Post Processing for Lift and Drag Coefficients
Inaam Ahnaf
AhnafInaam is on a distinguished road
For the Ansys Fluent application tab, I was able to simulate the transonic flow over the circular and square cylinders at different Mach numbers.
In Ansys CFD post, how can I do the following things:
1) Display the Cd change with respect to mach number regarding the square and circular cylinder
2) Display the lift coefficient distribution across the surface regarding the circular and square cylinder
3)Display the drag coefficient distribution across the surface regarding the circular and square cylinder
4) Shock induced separation through velocity streamlines.
For your Information:
I know how to save the Ansys Fluent data and case files in .dat and .cas respectively.
AhnafInaam is offline   Reply With Quote
How to extract Lift and Drag coefficients from Ansys Fluent Abdul_Rehman FLUENT 9 March 22, 2021 09:37
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
Force Function Calculator Ansys CFD Post sharadram1989 CFX 22 October 30, 2019 05:07
Post Processing Drag Coefficient squanto773 OpenFOAM Post-Processing 1 March 7, 2012 10:43
Final Year Project - CFD on Drag coefficients jamesho123 Main CFD Forum 1 September 15, 2009 22:50
