Convergence issues in Supersonic flow
Old   July 6, 2023, 08:05
Default Convergence issues in Supersonic flow
Ashwin
Alpha_Ashwin007 is on a distinguished road
I'm trying to simulate the flow in a 2-d duct under Supersonic Conditions.
Inlet -
M = 1.7
Total pressure =0.207Mpa
Total Temperature = 310K
Static pressure = 42Kpa
k-w SST model
I have tried using both density and pressure-based solvers. In both cases, the continuity residual is not converging, and I am getting the wrong solution(As compared to experimental results). I am not getting the shock train in the solution.
After a while, the residuals just oscillate slightly and never decrease.
Any advice on solving this would be great.
I have attached a picture of the mesh below.
Thanks
Alpha_Ashwin007 is offline   Reply With Quote
Old   July 6, 2023, 08:16
Laurens
LJA_Koers is on a distinguished road
This is a relatively simple geometry. If you use hybrid initialization, chances are it is already quite close to the final and correct solution. The residuals are scaled to the initial solution (plus a few iterations), so if that initial solution is already quite good, the residual won't decrease much with further iterations, but that doesn't mean the solution is bad. The Fluent user manual discusses this in a section called 'convergence and stability'.
edit: forgot that your results don't match the experiments, I need to think about this some more.
LJA_Koers is offline   Reply With Quote
Old   July 6, 2023, 09:20
Ashwin
Thank you for your reply, Even if the continuity residual doesn't converge, I find other properties and residuals keep slightly oscillating after a point. Should I just let it run for an even longer time?
Old   July 6, 2023, 20:46
Lucky
The boundary conditions don't sound right.
2 MPa total pressure and 42 kPa at an inlet is wayyyy more than a Mach number of 1.7. Is 42 kPa the outlet pressure? What is the supersonic static pressure at the inlet?
The mesh is cool and dense but I can already see a kink line in the grid at the ramp which conveniently is where the high speed flow meets the pressure jump at the outlet.
Old   July 6, 2023, 23:26
Ashwin
I'm sorry, it was a typo. The total Inlet pressure is 0.207 Mpa and the supersonic static pressure is 42Kpa.
Any ideas on how to fix this? Thanks
Edit: By playing around with the options, I found that by using the 3rd order MUSCL Scheme with the density based solver with k-w SST, the results seem to be close, but the residuals and properties have a slight oscillation in them. Are these problems due to the mesh?
I have attached some plots for your reference. Thank You
continuity residual, fluent, supersonic inlet
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Test Case CFL Number Issues with Software Update JBCFD SU2 3 July 14, 2017 13:05
Supersonic flow in a duct ecto STAR-CCM+ 1 July 6, 2017 13:00
[How to obtain supersonic flow inside a supersonic wind tunnel ?] yx213 Siemens 1 September 17, 2014 14:52
Jet in Supersonic Crossflow, controlling mass flow rate ChrisA OpenFOAM Running, Solving & CFD 3 November 13, 2012 19:20
