June 30, 2023, 07:52 |
UDF Error: Error code 126
Cillian Thomas
Rep Power: 3 |
Hi Everyone,
I have been struggling with loading a custom UDF now for a couple of days. I am using ANSYS 2021R1 and visual studio 2017. I have followed the relevant steps and added to following enviroment variables (these are as close to the instructions for VS10 as given in the FAQ as I could get) I launch fluent from x64 Native tools prompt, in my working director with case files. When I build my UDF I get: Code:
Copied C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent/C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\exampleudf.c to libudf\src (system "copy "c:\PROGRA~1\ANSYSI~1\v211\fluent"\fluent21.1.0\src\udf\sconstruct.udf "libudf\win64\3ddp_host\SConstruct" ") 1 file(s) copied. (system "copy "c:\PROGRA~1\ANSYSI~1\v211\fluent"\fluent21.1.0\src\udf\scons_default.bat "libudf\win64\3ddp_host\scons_test.bat" ") 1 file(s) copied. Files udf_names.c and user_nt.udf in 3ddp_host are up-to-date. (system "copy "c:\PROGRA~1\ANSYSI~1\v211\fluent"\fluent21.1.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_host") C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf\win64\3ddp_host>rem C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf\win64\3ddp_host>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved. C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf\win64\3ddp_host>rem Microsoft (R) C/C++ Optimizing Compiler Version 19.10.25027 for x64 Copyright (C) Microsoft Corporation. All rights reserved. usage: cl [ option... ] filename... [ /link linkoption... ] Microsoft (R) Program Maintenance Utility Version 14.10.25027.0 Copyright (C) Microsoft Corporation. All rights reserved. (system "copy "c:\PROGRA~1\ANSYSI~1\v211\fluent"\fluent21.1.0\src\udf\sconstruct.udf "libudf\win64\3ddp_node\SConstruct" ") 1 file(s) copied. (system "copy "c:\PROGRA~1\ANSYSI~1\v211\fluent"\fluent21.1.0\src\udf\scons_default.bat "libudf\win64\3ddp_node\scons_test.bat" ") 1 file(s) copied. Files udf_names.c and user_nt.udf in 3ddp_node are up-to-date. (system "copy "c:\PROGRA~1\ANSYSI~1\v211\fluent"\fluent21.1.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_node") C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf\win64\3ddp_node>rem C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf\win64\3ddp_node>rem Copyright 1987-2021 ANSYS, Inc. All Rights Reserved. C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf\win64\3ddp_node>rem Microsoft (R) C/C++ Optimizing Compiler Version 19.10.25027 for x64 Copyright (C) Microsoft Corporation. All rights reserved. usage: cl [ option... ] filename... [ /link linkoption... ] Microsoft (R) Program Maintenance Utility Version 14.10.25027.0 Copyright (C) Microsoft Corporation. All rights reserved. Done. Code:
mme144143: Opening library "C:\RANS c drive\rans_c_drive_files\dp0\FLU-12\Fluent\libudf"... Error at Node 1: Error code: 126 Error at Node 4: Error code: 126 Error at Node 2: Error code: 126 Error at Node 3: Error code: 126 Error at Node 6: Error code: 126 Error at Node 5: Error code: 126 Error at Node 7: Error code: 126 Error at Node 8: Error code: 126 Error at Node 9: Error code: 126 Error at Node 10: Error code: 126 Error at Node 12: Error code: 126 Error at Node 11: Error code: 126 Error at Node 13: Error code: 126 Error at Node 14: Error code: 126 Error at Node 15: Error code: 126 Error at Node 0: Error code: 126 Error at Node 16: Error code: 126 Error at Node 19: Error code: 126 Error at Node 17: Error code: 126 Error at Node 18: Error code: 126 Error at host: Error code: 126 Error: Error code: 126\n Error Object: #f My UDF files is Code:
exampleudf.c /*********************************************************************** udfexample.c UDF for specifying steady-state velocity profile boundary condition ************************************************************************/ #include "udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y, h; face_t f; h = 0.016; /* inlet height in m */ begin_f_loop(f,thread) { F_CENTROID(x, f, thread); y = 2.*(x[1]-0.5*h)/h; /* non-dimensional y coordinate */ F_PROFILE(f, thread, position) = 0.1*(1.0-y*y); } end_f_loop(f, thread) } I appreciate any help, Cillian |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 03:18 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 13:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
