June 28, 2023, 09:45 |
Reference Values Section Confusion in Fluent
Sakun
Rep Power: 6 |
I am simulating a single compressor blade in fluent and i would like to know what sort of a values, i have to put for Area and Length in the fluent Reference Values section. According to the picture, blue arrows indicates the surface of the INLET. Regards, |
June 29, 2023, 03:41 |
Luca
Rep Power: 5 |
Within the Fluent environment, Reference Values are used to calculate coefficients; in particular I think that the length is useful for the Re estimation and the area for the lift and drag coefficients. You need to set them consistently with your problem. Usually for airfoils the length is the chord and the area is the planform area, not sure how to deal with the values considering a compressor blade.
June 29, 2023, 08:03 |
Lucky
Rep Power: 66 |
Clarification, you only need to set reference values if you plan to use the calculated coefficients for your problem.
For compressor blades, where we rarely use Cd and Cl, or for problems where Cd and Cl are not relevant at all, you can set the reference values to anything, just leave it alone. |
compressible flow, compressor blade, fluent |
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate | Kieyo | Fluent Multiphase | 0 | November 9, 2022 23:58 |
It would be wonderful if a tool for FoamToTecplot is available | luckyluke | OpenFOAM Post-Processing | 165 | November 27, 2012 06:54 |
Fluent 2D Reference Values | Adam | FLUENT | 1 | January 16, 2009 02:58 |
Why's FLUENT changing the reference values? | siw | FLUENT | 0 | November 6, 2008 13:17 |
Windows Installation BugsComments on Petrbs patch | brooksmoses | OpenFOAM Installation | 48 | April 16, 2006 00:20 |
