June 19, 2023, 03:30 |
Fluent Setup; continuity residual
sairamprasad
Rep Power: 3 |
I am working on transient analysis of multiphase water entry body (3-Dimensional) using VOF, k-omega SST turbulence model, with velocity inlet and pressure outlet boundary conditions, overset mesh, dynamic mesh zone conditions, while running calculations for a time step size of 0.01, number of time steps 100, max iterations as 90 after completing max iterations my continuity residual gets a straight line from 15 iterations, rest of all velocities and k, omega residuals gets converged which i have taken convergence criterion as 1e-05. what could be the reason for the continuity residual being a straight line?
June 21, 2023, 10:46 |
Kareem
Rep Power: 3 |
Depending on the model the time step of .01 seconds is pretty big for a VOF model. I would check your CFL number. You should try to keep your CFL number under 1 by reducing the timestep. This should also help your solution converge.
A general rule of thumb is that it is faster to use a small timestep that converges in less iterations then a larger step. You should aim for each timestep to converge in 10-20 iterations.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
dynamic mesh zones, overset mesh, transient 3d, turbulence modelling |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
