June 17, 2023, 15:03 |
Boundary conditions
vahid
Rep Power: 3 |
Hello, good time.
If I have named selection two face as one inlet, the number I give as mass flow inlet is divided by two or the same number is considered for both face. |
June 18, 2023, 12:22 |
Lucky
Rep Power: 66 |
Sry the post is confusing. Named selections are just tags used as shortcuts. There is never any division by two but what matters is how many boundaries you have. Using named selections will make the corresponding boundaries a mass flow inlet. You can have multiple named selection point to one boundary or you can have one named selection point to multiple boundaries.
How many boundaries do you have? Each boundary will be a mass flow rate boundary condition. Each boundary then will have the set mass flow rate. If you have 1 boundary that means you have 1 boundary with the flowrate. If you have 10 boundaries ,that means you have 10 inlets each with the flowrate so your total is 10x that amount. If you have no boundaries then you have no flow at all. |
#ansys, #boundary, #fluent, #inlet, #mass-flow-inlet |
Question about different kinds of Boundaries and Boundary Conditions | granzer | Main CFD Forum | 17 | April 12, 2022 17:27 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
