Treatment of solid - fluid interaction in Conjugate heat transfer
Old   June 16, 2023, 02:43
Default Treatment of solid - fluid interaction in Conjugate heat transfer
Zoro_07
PratikJ is on a distinguished road
Dear all,
I have some doubt regarding the setting the boundary conditions in case of conjugate heat transfer.
Let me brief the physics involved : 1 internal fluid (fluid1) with inlet and outlet, 2 solid layers(solid1, solid2) surrounding fluid1 in layered manner, fluid2 surrounding solid2 with inlet and outlet, solid3 surrounding fluid2, fluid2 again surrounding solid3.
So now, in this case, what should be the boundary conditions at the interface of, i. e. interface between fluid1 - solid1, solid1 - solid2, solid2 - fluid2, fluid2 - solid3, solid3 - fluid2.
Considering I want the conduction in solids too.... should interfaces need to be consider as 'internal' or 'wall' boundary condition ? and how to patch those interface ?
PratikJ is offline   Reply With Quote
Old   June 28, 2023, 06:40
Moritz Kuhn
MKuhn is on a distinguished road
An internal boundary condition you have only between two fluids zones or two solid zones. You need a coupled wall boundary, so that you have a wall connected to the fluid zone and a wall-shadow connected to the solid zone. In this case you have a heat flow form solid and fluid and vice versa.
MKuhn is offline   Reply With Quote
boundaries condition, conjugate heat transfer, interface domains, solid fluid contact, solid fluid interaction
Help needed in meshing for Solid to Fluid Heat Transfer niazaliahmed FLUENT 2 February 22, 2020 16:47
Conjugate heat transfer between rotating fluid and solid srikarg OpenFOAM Pre-Processing 0 November 22, 2019 02:56
Multiphase heat transfer pkladisios CFX 8 June 7, 2016 02:41
Heat transfer between solid rotating and stationary fluid domains DCSERE CFX 2 November 17, 2015 04:43
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
