I Really Desperate For Help, Floating Point Exceed |
Agung
Rep Power: 3 ![]() |
I Have model and i've been struggling for 5 days with this fluent issue. It always says that my floating point is exceeded and i have tried everything including re-meshing (Which doesn't have significant changes) and reducing timestep. Anything can help me. Can it be like a memory issue because I run this in really tight memory
My model have 13 m cell and i run it on Core I7, 16 GB RAM. the console error says Stabilizing k to enhance linear solver robustness. Stabilizing k using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: k Stabilizing omega to enhance linear solver robustness. Stabilizing omega using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: omega Stabilizing temperature to enhance linear solver robustness. Stabilizing temperature using GMRES to enhance linear solver robustness. Divergence detected in AMG solver: temperature Error at host: floating point exception |
#2 | |
I don't think this a memory issue, as a base line setup I always run the simulation on a coarse mesh. Does that help? If that works, then go to medium or fine mesh. Secondly, turn off equations for turbulence and let velocity and pressure settle for 300-400 iterations, then turn turbulence back on. |
Kareem
The divergence in the solver means that the numeric are diverging and leading to the floating point error.
I would double check your boundary conditions, mesh quality, and solver settings. This kind of divergence is common when you have poor mesh quality. A single mesh of very poor quality can lead to divergence in the solver.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
floating point exception, fluent, meshing |
Understanding The Floating Point Exception Error Message | RussellHolt | OpenFOAM Running, Solving & CFD | 2 | August 6, 2022 00:00 |
InterFoam based solver running into floating point error on restarting simulation | Venky_94 | OpenFOAM Running, Solving & CFD | 9 | November 23, 2021 16:53 |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
