Fluent fan models and GPU enabled HPC compute |
Zac
Rep Power: 0 ![]() |
I am currently attempting to run a simulation in Fluent 2023R1 on a HPC.
It’s a 3D pressure based simulation where I have two fan models present. It seems that the propellers are momentum models and I cannot find a way around this. As a result – the simulation will not run when fans are present. I have tried to force the models to pressure based – but I still receive the same error. The following is the ANSYS output: “> /define/models/solver/density-based-explicit no No change. > /define/models/solver/density-based-implicit no No change. > /define/models/solver/pressure-based yes > /solve/initialize/hyb-initialization turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 10429708 cells Note: Settings to improve the robustness of pathline and particle tracking have been automatically enabled. Preparing GPU solver, please wait ... -------------------------------------------------------------------------------------------------------------------------------------------------- Rank PID Core OS Host Device Name Version Memory(GB) Bandwidth(GB/s) Cores -------------------------------------------------------------------------------------------------------------------------------------------------- GPU specs listed here – supported A100 Nvidia Cards -------------------------------------------------------------------------------------------------------------------------------------------------- Bandwidth : 5.12507 GB/s Latency : 0.783927 usec Please modify the following unsupported settings before proceeding (2) ************************************* Equation Zone ID Type ------------------------------------- momentum auv_propeller 87 jump momentum xluuv_propeller 82 jump Error: Failed to setup GPU Solver” In the journal file, I model to fan models with the following commands: “/define/boundary-conditions/zone-type 87 fan /define/boundary-conditions/zone-type 82 fan . . . /define/boundary-conditions/zone-name 87 auv_propeller /define/boundary-conditions/zone-name 82 xluuv_propeller /define/boundary-conditions/fan xluuv_propeller 1 no constant 0 no 0 0 yes no -16000 yes () () 0.5 0 0 0 1 0 0 yes no 5.729 yes no 0 /define/boundary-conditions/fan auv_propeller 1 no constant 0 no 0 0 yes no -5000 yes () () 0.02 0 0 0 1 0 0 yes no 5.729 yes no 0” Cheers, C |
fan bc, fluent, hpc, tui command |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 02:48 |
