June 6, 2023, 04:01 |
Getting an error while compiling UDF code
Sohrab S
Hello everyone,
I am trying to use a user defined function that receives the pressure of a specific area as input and changes the air density in that area. The relevant thermodynamic equations are visible within the code. Problem is, when I try to compile the code, I receive the following error: "The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64)". Could you please take a look at my code and see what is wrong with it? The code I am using is: #include "udf.h" DEFINE_PROPERTY(Density, c, t) { real RHOat; /* air density in the atmosphere */ real rho; /* air density inside the Chamber */ real Pch; /* pressure inside the Chamber */ real Pat; /* Atmospheric pressure */ Pat = 101325; RHOat = 1.225; Pch = C_P(c, t); if (Pch >= Pat) rho = (Pat * RHOat) / (Pat + Pch); else rho = (RHOat * (Pat + Pch)) / Pat; return rho; } |
June 6, 2023, 04:20 |
Damir
Rep Power: 3 |
Try to use visual studio for compilation.
Also try to run without parallel computing. Last edited by salkynbekov; June 7, 2023 at 04:39. |
June 6, 2023, 08:22 |
Sohrab S
Thanks for the reply, I use Visual Studio 2010 for compiling and I have tried to run the simulation without parallel computing, same error appears!
cfd, density change, udf code, udf compile |
Compiling my own source code: 'libNULL.so' is up to date | MrNinainaidi | OpenFOAM Programming & Development | 1 | November 30, 2020 06:27 |
Compiling the customized UDF code for PEMFC | dmfo | Fluent UDF and Scheme Programming | 2 | October 1, 2017 19:30 |
write code UDF Fluent solve kinetic reaction rate equation palm oil | zirkov | FLUENT | 0 | February 13, 2017 11:16 |
something wrong when compiling udf, however the code is correct when interpreting | richard ben | Fluent UDF and Scheme Programming | 7 | May 11, 2013 08:36 |
ERROR in compiling UDF | stefanos | Fluent UDF and Scheme Programming | 1 | April 25, 2012 08:37 |
