UDF problem with specific heat
Old   June 5, 2023, 06:03
Default UDF problem with specific heat
Damir
salkynbekov is on a distinguished road
I am modeling PCM using solidifcation/melting module in ANSYS FLUENT.
(laminar, transient simualtion)
to define properties of the PCM, I use UDF.
and for specific heat I have following:
DEFINE_SPECIFIC_HEAT(cell_cp,T, Tred,h,yl)
    real cp;
    if(T < T_m) {cp = f(T);}
    else {cp = 2150;}
    *h = cp*(T-Tref);
    return cp;
But it errors as
"Warning: invalid cp (-1.15454545 J/kgK) for PCM at temperature 230.5151 K"
As you see in udf there can not be negative specific heat.
best regards.
salkynbekov is offline   Reply With Quote
Old   June 8, 2023, 08:51
Moritz Kuhn
MKuhn is on a distinguished road
Check your polynome. For 230 K I get a negative value as well. Anyway, you do not have to define the specific heat with an UDF. The possibilities in the material data panal are sufficient, as you can define even stepwise polynomes for temperature depend data.
MKuhn is offline   Reply With Quote
ansys fluent, pcm modeling, specific heat, udf and programming
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
UDF for Specific Heat - Problem Hamjaj Fluent UDF and Scheme Programming 17 June 17, 2017 02:28
UDF for defining specific heat ratio,gas constant,molecular weight n.soumya Fluent UDF and Scheme Programming 6 February 17, 2016 09:37
fluent udf problem: write specific data for every iteration in a file. nnvoro Fluent UDF and Scheme Programming 1 May 27, 2013 16:26
Specific Heat (Cp) cannot be calculated by UDF??? João Fernandes FLUENT 0 October 16, 2008 19:58
