Turbulence value in boundary condition
Old   June 1, 2023, 01:09
Default Turbulence value in boundary condition
Ann Sal
annsal is on a distinguished road
I modeled PM dispersion in urban areas. the average wind velocity is 0.8 m/s. I'm using the k and Epsilon models, but in boundary conditions should I choose k and epsilon in turbulence or can I use different choices like intensity and viscosity ratio?
annsal is offline   Reply With Quote
Old   June 1, 2023, 09:11
Lucky
You can use whatever combination you find convenient.
The actual boundary condition being given to the transport equation is k and epsilon and that is what Fluent needs and uses. The other methods are calculators provided to convert turbulence intensity and length scale into k and epsilon. If you know k and epsilon, use it. If you know something else, you may use those. If you know how to convert intensity and length scale into k and epsilon, you may do so. If not, Fluent does it for you.
fluent, pm dispersion, turbulence analysis
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
