gaurav
Rep Power: 0 ![]() |
I want to calculate coefficeint of drag (Cd) using fluent; for the flow over cylinder in 2-dimensional domain:Dia of cylinder= 0.1 m
Re=2x10^4 what Reference values should I used in fluent to find the Cd as defaults values are 1 for area,depth and length. Area=?density=1.225 Depth=? Length=? Velocity=2.93 Viscosity=1.7894e-05 When I calculated Cd using Report>Forces> cylinder wall>coefficient of drag. the results are not matched with available experimental results |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 02:19 |
How to implement time-varying boundary conditions in an enclosed cylinder | Alejandro-FA | OpenFOAM Pre-Processing | 0 | May 14, 2020 06:29 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 16:16 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 06:01 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
