ANUDEEPGUPTAGRANDHE
Rep Power: 0 ![]() |
I wanted to generate freestream data for a external aerodynamic simulation to get values of forces and moments acting on body.
In freestream analysis there are lot many parameters like Angle of attack , angle of side slip, mach number, altitude etc., By keeping fixed mach number & varying angle of attack from small to higher AoA I will run n number of cases and will do the same for all other mach numbers., where test cases will be around 100. By changing altitude the only aerodynamic force will change is axial force(Ca) remaining all other parameters will be same like (Cn, Cl, Cp center of pressure value, Cm values) My question here is , weather we need to run all test cases, at each n every altitude again n again ? Or is there any way to interpret the data where I ran test cases at sea level condition!!!! |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Forces and Moments Given by forces Function Object are not Perpendicular | Ship Designer | OpenFOAM Post-Processing | 1 | February 6, 2022 23:32 |
Convergence problem of OF | WUYing | OpenFOAM Running, Solving & CFD | 2 | September 20, 2021 10:09 |
Calculating Aerodynamic Forces and Moments | jomunkas | SU2 | 0 | July 23, 2020 17:11 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
