Geometry and boundary setting for 2 different material |
Lee
Rep Power: 0 ![]() |
I am currently trying to simulate metal hydride reaction in Fluent. The pressured hydrogen react with metal(porous zone) and I use UDF for mass and energy source term. The reaction is: LaNi5 + 3H2 -> LaNi5H6. I firstly tried with only porous zone and it worked. Now, I am trying to change the geometry like attachment. When I initialize it, the pressure of the gas zone is okay, but not for the porous zone (it shows zero) which should be 8 bar as I set initialization. Other value looks fine tho, such as temperature, density, species... Only pressure is issue, therefore, I could not see the reaction with this geometry. For the geometry, I used Add-frozen and had two surface bodies. I think the interface between the two zone is recognised as a wall. So the gas is just remained in gas zone. So my question is: 1. Should I separate two part for this problem? How can I make hydrogen go through interface? 2. If not, how can I assign two zone in one cell zone? |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
An error occurs.'Increase the file catalog size. ' | dhehdxhdaus | CFX | 3 | April 10, 2022 20:13 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Setting Boundary Conditions for stl geometry (periodic cooling fin tunnel) | gelbebanane | OpenFOAM Pre-Processing | 3 | December 6, 2013 13:56 |
